Nintendo WaveBird Wireless Controller Motherboard Replacement
  1. Nintendo WaveBird Wireless Controller Motherboard Replacement, Batteries: step 1, image 1 of 2 Nintendo WaveBird Wireless Controller Motherboard Replacement, Batteries: step 1, image 2 of 2
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller Motherboard Replacement: step 2, image 1 of 1
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller Motherboard Replacement, Front Panel: step 3, image 1 of 2 Nintendo WaveBird Wireless Controller Motherboard Replacement, Front Panel: step 3, image 2 of 2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller Motherboard Replacement: step 4, image 1 of 2 Nintendo WaveBird Wireless Controller Motherboard Replacement: step 4, image 2 of 2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
  5. Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: step 5, image 1 of 3 Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: step 5, image 2 of 3 Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
  6. Nintendo WaveBird Wireless Controller Motherboard Replacement, Motherboard: step 6, image 1 of 1
    Buy
    • Using tweezers remove the three grey button pads from the motherboard.
  7. Nintendo WaveBird Wireless Controller Motherboard Replacement: step 7, image 1 of 1
    • With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
    • To put the motherboard back into place, align the two metal clips under the motherboard with the slots in the back panel. The motherboard should fall into place.
7 other people completed this guide.
Travis Taylor
521 Reputation
5 Guides authored
Cal Poly, Team 10-40, Amido Spring 2013 Member of Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Members
37 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 42
All Time: 9,157
