Nintendo Wii Remote Main Buttons Replacement
  1. Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: step 1, image 1 of 2 Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: step 1, image 2 of 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote Main Buttons Replacement: step 2, image 1 of 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Main Buttons Replacement: step 3, image 1 of 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Main Buttons Replacement: step 4, image 1 of 2 Nintendo Wii Remote Main Buttons Replacement: step 4, image 2 of 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
  5. Nintendo Wii Remote Main Buttons Replacement, Main Buttons: step 5, image 1 of 2 Nintendo Wii Remote Main Buttons Replacement, Main Buttons: step 5, image 2 of 2
    • Working on the inside of the front cover, peel off the three rubber pads covering the buttons.
  6. Nintendo Wii Remote Main Buttons Replacement: step 6, image 1 of 1
    • Flip over the cover, allowing the buttons to fall into your hand.
    • Be ready to catch all the buttons, some are very small. If a button does not fall out apply gentle pressure from behind.
    • When reassembling, put each plastic button in its allocated slot. Each button only fits snugly in one slot.
    • The best option for you is rotate the Wii Controller by 180°. If you obey this note, the small parts wont fall off and then you can remove the buttons.
27 other people completed this guide.
Emily
1,935 Reputation
6 Guides authored
Cal Poly, Team 3-44, Amido Spring 2013 Member of Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Members
29 Guides authored
5 Guide Comments
Where did you get your replacement buttons? I can't find them online anywhere...
devannedloss - Reply
Me too, can’t find them.
Michael Velten -
2024 and can't find them online ANYWHERE! I'm hoping a WiiUDpad fits on the wiimote. You'd think there'd be a bunch of wiimote shells of different colours available everywhere online, but they're nowhere to be found
how frustrating!
MartianIsotopes - Reply
Vinted is full of them. Although some people ask wayyy too much for them!
Sophie Nicholson -
Yo tampoco los encuentro por ninguna parte
kinoto taller - Reply
Past 24 Hours: 18
Past 7 Days: 138
Past 30 Days: 382
All Time: 46,883
