Nintendo Wii mini Disc Drive Replacement
  1. Nintendo Wii mini Disc Drive Replacement, Unscrew the Bottom: step 1, image 1 of 2 Nintendo Wii mini Disc Drive Replacement, Unscrew the Bottom: step 1, image 2 of 2
    • Remove the two rubber feet at the back of the console to reveal the hidden screws.
    • Remove the four 6mm Phillips #0 screws.
  2. Nintendo Wii mini Disc Drive Replacement, Remove the Cover: step 2, image 1 of 3 Nintendo Wii mini Disc Drive Replacement, Remove the Cover: step 2, image 2 of 3 Nintendo Wii mini Disc Drive Replacement, Remove the Cover: step 2, image 3 of 3
    • Turn the Wii mini right-side up. Then run a plastic opening tool around the middle edge of the console to loosen the top piece.
    • Gently lift the top piece of the console and set it aside.
  3. Nintendo Wii mini Disc Drive Replacement, Unscrew the Fan: step 3, image 1 of 2 Nintendo Wii mini Disc Drive Replacement, Unscrew the Fan: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Turn the Wii mini around so that the back of the device is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the two 6mm screws on either side of the fan piece.
    • You may need to use tweezers to pull out the screws once they are loosened.
  4. Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: step 4, image 1 of 3 Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: step 4, image 2 of 3 Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: step 4, image 3 of 3
    • Using your fingers, gently pull the top of the pin connector straight up to detach the fan from the console.
    • Do not wiggle the connector or cable while removing. This may cause the connector to come loose
    • Remove the fan piece and set it aside.
  5. Nintendo Wii mini Disc Drive Replacement, Power Board: step 5, image 1 of 3 Nintendo Wii mini Disc Drive Replacement, Power Board: step 5, image 2 of 3 Nintendo Wii mini Disc Drive Replacement, Power Board: step 5, image 3 of 3
    • Using your fingers, slide out the blue ribbon cable from the the top of the power board.
    • Using a Phillips #0 Screwdriver, unscrew the two 4mm screws at the top and bottom of the power board.
  6. Nintendo Wii mini Disc Drive Replacement: step 6, image 1 of 2 Nintendo Wii mini Disc Drive Replacement: step 6, image 2 of 2
    • Using your fingers, gently pull the pin connector to disconnect the power board from the disc drive.
  7. Nintendo Wii mini Disc Drive Replacement: step 7, image 1 of 2 Nintendo Wii mini Disc Drive Replacement: step 7, image 2 of 2
    • Lift the power board from the console and set it aside.
  8. Nintendo Wii mini Disc Drive Replacement, Disc Drive: step 8, image 1 of 2 Nintendo Wii mini Disc Drive Replacement, Disc Drive: step 8, image 2 of 2
    • Using a Phillips #0 Screwdriver, unscrew the four 6mm screws.
  9. Nintendo Wii mini Disc Drive Replacement: step 9, image 1 of 2 Nintendo Wii mini Disc Drive Replacement: step 9, image 2 of 2
    • Lift the disc drive out of the console and set it aside.
3 other people completed this guide.
Kristin Anderson
996 Reputation
5 Guides authored
UWT Liner: Group 5 Member of UWT Liner: Group 5
Community
3 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 34
Past 30 Days: 114
All Time: 5,590
