Nintendo Wii mini Fan Replacement
  1. Nintendo Wii mini Fan Replacement, Unscrew the Bottom: step 1, image 1 of 2 Nintendo Wii mini Fan Replacement, Unscrew the Bottom: step 1, image 2 of 2
    • Remove the two rubber feet at the back of the console to reveal the hidden screws.
    • Remove the four 6mm Phillips #0 screws.
  2. Nintendo Wii mini Fan Replacement, Remove the Cover: step 2, image 1 of 3 Nintendo Wii mini Fan Replacement, Remove the Cover: step 2, image 2 of 3 Nintendo Wii mini Fan Replacement, Remove the Cover: step 2, image 3 of 3
    • Turn the Wii mini right-side up. Then run a plastic opening tool around the middle edge of the console to loosen the top piece.
    • Gently lift the top piece of the console and set it aside.
  3. Nintendo Wii mini Fan Replacement, Unscrew the Fan: step 3, image 1 of 2 Nintendo Wii mini Fan Replacement, Unscrew the Fan: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Turn the Wii mini around so that the back of the device is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the two 6mm screws on either side of the fan piece.
    • You may need to use tweezers to pull out the screws once they are loosened.
  4. Nintendo Wii mini Fan Replacement, Detach the Fan Connector: step 4, image 1 of 3 Nintendo Wii mini Fan Replacement, Detach the Fan Connector: step 4, image 2 of 3 Nintendo Wii mini Fan Replacement, Detach the Fan Connector: step 4, image 3 of 3
    • Using your fingers, gently pull the top of the pin connector straight up to detach the fan from the console.
    • Do not wiggle the connector or cable while removing. This may cause the connector to come loose
    • Remove the fan piece and set it aside.
3 other people completed this guide.
Kristin Anderson
996 Reputation
5 Guides authored
UWT Liner: Group 5 Member of UWT Liner: Group 5
Community
3 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 38
All Time: 1,677
