Nite Ize Inova Microlight Battery Replacement
  1. Nite Ize Inova Microlight Battery Replacement, Case Removal: step 1, image 1 of 2 Nite Ize Inova Microlight Battery Replacement, Case Removal: step 1, image 2 of 2
    • Insert the plastic opening tool into the seam of the device.
  2. Nite Ize Inova Microlight Battery Replacement, Battery Removal: step 2, image 1 of 3 Nite Ize Inova Microlight Battery Replacement, Battery Removal: step 2, image 2 of 3 Nite Ize Inova Microlight Battery Replacement, Battery Removal: step 2, image 3 of 3
    • Squeeze the top battery using a tweezer and pull the battery away from the light bulb.
    • Repeat this step for the bottom remaining battery.
    • Do not pull up on the battery as this will bend the metal contact.
4 other people completed this guide.
Jennifer Tabadero
526 Reputation
3 Guides authored
CSU Fullerton, Team 2-1, Bruce Fall 2014 Member of CSU Fullerton, Team 2-1, Bruce Fall 2014
CSUF-BRUCE-F14S2G1
3 Members
3 Guides authored
One Comment
There is another Inova flashlight design that involves removing two Phillips type screw heads that are VERY TINY. I am able to unscrew one, but not the other, so am stuck and unable to replace the batteries.
Chrystin - Reply
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 39
All Time: 5,697
