Nivona Caferomatica 770 Grinder opening
VauWeh
VauWeh and 2 other contributors
Last updated on February 21, 2025
No estimate
Moderate
Community-Contributed Guide
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
Introduction
Go to step 1
These instructions may also help with other Nivona models and with coffee makers from Melitta, Siemens, and Miele—they are all made by the same manufacturer and have a very similar design.
To access the grinder, the machine must be opened. Then the grinder can be removed completely or only the grinding stones can be replaced. The grinder is the same as in many devices from Siemens, Melitta, Jura, Bosch, etc. installed.
Tools
  1. Nivona Caferomatica 770 Grinder opening, opening procedure: step 1, image 1 of 1
    • Pull the power plug!
    • Remove all attachments such as water reservoir, coffee compartment lid, trestle drawer. Remove all coffee beans in the storage container.
    • Unscrew the five Torx T10 screws on the back.
  2. Nivona Caferomatica 770 Grinder opening: step 2, image 1 of 3 Nivona Caferomatica 770 Grinder opening: step 2, image 2 of 3 Nivona Caferomatica 770 Grinder opening: step 2, image 3 of 3
    • Unscrew the two Torx T10 screws on the front edge of the heat plate.
    • Do not remove the heat plate completely yet, its supply cables are still connected.
    • Lift the front edge of the heat plate and slide it forward a bit to clear the tabs on the back edge.
    • Put the heat plate back down, but in such a way that you can reach the screws underneath.
    • Unscrew the two Torx T10 screws located under the heat plate.
  3. Nivona Caferomatica 770 Grinder opening: step 3, image 1 of 3 Nivona Caferomatica 770 Grinder opening: step 3, image 2 of 3 Nivona Caferomatica 770 Grinder opening: step 3, image 3 of 3
    • Gently lift the upper side a bit and put it back down.
    • Push the side panel on the water tank back about 2 cm.
    • This may jam a bit.
    • Place the side panel next to the machine. Do not remove it completely yet, the cables of the switch are still connected.
    • Disconnect the flat plugs from the switch. Be sure to note the order of the cables for later reassembly.
    • Remove the side panel.
  4. Nivona Caferomatica 770 Grinder opening: step 4, image 1 of 1
    • Loosen the two insulated flat plugs with which the heat plate is connected.
    • Lift the top slightly upwards and loosen the nut that secures the eyelet to the green-yellow grounding cable. Remove the eyelet.
    • Do not remove the top yet, it is still connected with a sensor cable.
  5. Nivona Caferomatica 770 Grinder opening: step 5, image 1 of 2 Nivona Caferomatica 770 Grinder opening: step 5, image 2 of 2
    • Lift the top side slightly.
    • Press down the locking tab on the plug of the white sensor cable and pull off the black plug towards the front of the machine.
    • Press the two catches of the counterpart on the sides together and slide it out of the opening towards the back.
    • Now the top is free and you can remove it.
  6. Nivona Caferomatica 770 Grinder opening: step 6, image 1 of 1
    • Slide the side panel with the service door back about 2 cm and remove it.
    • This may jam a little.
  7. Nivona Caferomatica 770 Grinder opening, grinder: step 7, image 1 of 2 Nivona Caferomatica 770 Grinder opening, grinder: step 7, image 2 of 2
    • The grinder is damped with foam mats. One mat just rests on top. Remove it.
    • Work carefully, the mats tear easily.
    • The grinder is open in front of you.
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
248,052 Reputation
281 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
29 Members
1,752 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 9
All Time: 517
