Nixon Mission Android Wear Battery Replacement
  1. Nixon Mission Android Wear Battery Replacement, Battery: step 1, image 1 of 1
    • Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
  2. Nixon Mission Android Wear Battery Replacement: step 2, image 1 of 1
    • Remove the back plate of watch.
  3. Nixon Mission Android Wear Battery Replacement: step 3, image 1 of 1
    • Unclip 5 latches from motherboard using a plastic spudger.
  4. Nixon Mission Android Wear Battery Replacement: step 4, image 1 of 1
    • Remove the 2 3.0mm screws from motherboard using PH00 Phillips head.
  5. Nixon Mission Android Wear Battery Replacement: step 5, image 1 of 1
    • Carefully remove motherboard & internal screen.
  6. Nixon Mission Android Wear Battery Replacement: step 6, image 1 of 1
    • Remove from the motherboard the connector with the four cables.
    • Pull the cables upward and the motherboard downward as shown in the picture.
  7. Nixon Mission Android Wear Battery Replacement: step 7, image 1 of 1
    • Carefully remove the battery from the watch.
6 other people completed this guide.
Mauricio Ambrosio
191 Reputation
1 Guide authored
IUPUI, Team S3-G2, Harley Fall 2017 Member of IUPUI, Team S3-G2, Harley Fall 2017
IUPUI-HARLEY-F17S3G2
3 Members
3 Guides authored
18 Comments
Hi, would you be able to advise where to purchase a replacement battery?
Simon Seow - Reply
same here, where to purchase a replacement battery ?
peter.erdogyaraki - Reply
Thank you for your tuto.
But now, where I can purchase a new battery?
Thank you
COUTURIER - Reply
Hi! Anyone knows where to buy a new battery?
cristian.carvelli - Reply
After an extensive search there doesn't seem to be any info out there about battery sizeā€¦..still
Jerry Jerry J - Reply
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 56
All Time: 6,412
