Nixon Mission Android Wear Front Screen Replacement
  1. Nixon Mission Android Wear Front Screen  Replacement, Front Screen: step 1, image 1 of 1
    • Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
  2. Nixon Mission Android Wear Front Screen  Replacement: step 2, image 1 of 1
    • Remove the back plate of watch.
  3. Nixon Mission Android Wear Front Screen  Replacement: step 3, image 1 of 1
    • Unclip 5 latches from motherboard using a spudger.
  4. Nixon Mission Android Wear Front Screen  Replacement: step 4, image 1 of 1
    • Remove 2 3.0mm Phillips screws from motherboard using PH00 Phillips head.
  5. Nixon Mission Android Wear Front Screen  Replacement: step 5, image 1 of 1
    • Carefully remove motherboard & internal screen.
  6. Nixon Mission Android Wear Front Screen  Replacement: step 6, image 1 of 1
    • Remove 4 7.0mm hex-screws from front of watch using H1.5 Hex head.
  7. Nixon Mission Android Wear Front Screen  Replacement: step 7, image 1 of 1
    • Remove outer screen frame from front of watch.
  8. Nixon Mission Android Wear Front Screen  Replacement: step 8, image 1 of 1
    • Remove 4 4.5mm Phillips gold screws from back of watch using PH00 Phillips head.
  9. Nixon Mission Android Wear Front Screen  Replacement: step 9, image 1 of 1
    • Remove outer protective screen.
    • Replace outer protective screen with the new part.
Venkata
113 Reputation
1 Guide authored
IUPUI, Team S3-G2, Harley Fall 2017 Member of IUPUI, Team S3-G2, Harley Fall 2017
IUPUI-HARLEY-F17S3G2
3 Members
3 Guides authored
2 Guide Comments
But can you even buy replacement screen
Josh Leaney - Reply
Where can you buy a replacement screen?
Ethan Whitton - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 892
