Nobis NB07 Battery Replacement
  1. Nobis NB07 Battery Replacement, Opening the case: step 1, image 1 of 1
    • Look towards the topside of the tablet, where the power button is located.
    • Insert a plastic opening tool in the crack between the two parts of the case.
    • Move it gently back and forth to open the case.
  2. Nobis NB07 Battery Replacement: step 2, image 1 of 3 Nobis NB07 Battery Replacement: step 2, image 2 of 3 Nobis NB07 Battery Replacement: step 2, image 3 of 3
    • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
    • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
  3. Nobis NB07 Battery Replacement, Replacing the battery: step 3, image 1 of 3 Nobis NB07 Battery Replacement, Replacing the battery: step 3, image 2 of 3 Nobis NB07 Battery Replacement, Replacing the battery: step 3, image 3 of 3
    • Remove the tape holding the battery in place.
  4. Nobis NB07 Battery Replacement: step 4, image 1 of 3 Nobis NB07 Battery Replacement: step 4, image 2 of 3 Nobis NB07 Battery Replacement: step 4, image 3 of 3
    • Insert the flat end of the spudger tool in the crack beneath the battery.
    • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
    • This is a soft battery, so a little bending is expected.
  5. Nobis NB07 Battery Replacement: step 5, image 1 of 1
    • After the battery is unglued, locate the cables that connect it to the motherboard.
    • Annotate where each color goes to make the reassembly easier.
  6. Nobis NB07 Battery Replacement: step 6, image 1 of 2 Nobis NB07 Battery Replacement: step 6, image 2 of 2
    • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
    • Review the Ifixit soldering guide if you need help soldering.
    • You can now remove the battery.
3 other people completed this guide.
Daniel Gomero
966 Reputation
5 Guides authored
USF Tampa, Team 5-5, Brown Winter 2015 Member of USF Tampa, Team 5-5, Brown Winter 2015
USFT-BROWN-W15S5G5
3 Members
10 Guides authored
1 Guide Comment
where do you find that battery? tried searching by the numbers on it and nothing
Scott Tuttle - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 3,423
