Nobis NB07 Microphone Replacement
  1. Nobis NB07 Microphone Replacement, Opening the case: step 1, image 1 of 1
    • Look towards the topside of the tablet, where the power button is located.
    • Insert a plastic opening tool in the crack between the two parts of the case.
    • Move it gently back and forth to open the case.
  2. Nobis NB07 Microphone Replacement: step 2, image 1 of 3 Nobis NB07 Microphone Replacement: step 2, image 2 of 3 Nobis NB07 Microphone Replacement: step 2, image 3 of 3
    • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
    • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
  3. Nobis NB07 Microphone Replacement, Replacing the battery: step 3, image 1 of 3 Nobis NB07 Microphone Replacement, Replacing the battery: step 3, image 2 of 3 Nobis NB07 Microphone Replacement, Replacing the battery: step 3, image 3 of 3
    • Remove the tape holding the battery in place.
  4. Nobis NB07 Microphone Replacement: step 4, image 1 of 3 Nobis NB07 Microphone Replacement: step 4, image 2 of 3 Nobis NB07 Microphone Replacement: step 4, image 3 of 3
    • Insert the flat end of the spudger tool in the crack beneath the battery.
    • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
    • This is a soft battery, so a little bending is expected.
  5. Nobis NB07 Microphone Replacement: step 5, image 1 of 1
    • After the battery is unglued, locate the cables that connect it to the motherboard.
    • Annotate where each color goes to make the reassembly easier.
  6. Nobis NB07 Microphone Replacement: step 6, image 1 of 2 Nobis NB07 Microphone Replacement: step 6, image 2 of 2
    • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
    • Review the Ifixit soldering guide if you need help soldering.
    • You can now remove the battery.
  7. Nobis NB07 Microphone Replacement, Removing the cameras: step 7, image 1 of 3 Nobis NB07 Microphone Replacement, Removing the cameras: step 7, image 2 of 3 Nobis NB07 Microphone Replacement, Removing the cameras: step 7, image 3 of 3
    • Remove the black tape covering the cameras power cable.
  8. Nobis NB07 Microphone Replacement: step 8, image 1 of 2 Nobis NB07 Microphone Replacement: step 8, image 2 of 2
    • Use the spudger tool to pry upwards the ZIF connector and release the power cable.
  9. Nobis NB07 Microphone Replacement: step 9, image 1 of 3 Nobis NB07 Microphone Replacement: step 9, image 2 of 3 Nobis NB07 Microphone Replacement: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • With the power cable disconnected, the backside camera is free. However, both cameras are sequentially connected through the power cable; the front side camera is glued to the motherboard.
    • Using tweezers, carefully grab the front camera and twist slowly.
    • The camera should release easily, do not twist too hard.
    • You can now remove the cameras.
  10. Nobis NB07 Microphone Replacement, Removing the microphone: step 10, image 1 of 1
    • Locate the microphone's cables in front of the cameras' ZIF connector.
  11. Nobis NB07 Microphone Replacement: step 11, image 1 of 1
  12. Nobis NB07 Microphone Replacement: step 12, image 1 of 2 Nobis NB07 Microphone Replacement: step 12, image 2 of 2
    Buy
    • Use the pointy end of the tweezers to retrieve the microphone from its socket.
    • You can now remove the microphone.
Daniel Gomero
966 Reputation
5 Guides authored
USF Tampa, Team 5-5, Brown Winter 2015 Member of USF Tampa, Team 5-5, Brown Winter 2015
USFT-BROWN-W15S5G5
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 236
