Nokero N400 Back Cover Replacement
  1. Nokero N400 Back Cover Replacement, Remove Battery Cover: step 1, image 1 of 3 Nokero N400 Back Cover Replacement, Remove Battery Cover: step 1, image 2 of 3 Nokero N400 Back Cover Replacement, Remove Battery Cover: step 1, image 3 of 3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Back Cover Replacement, Unscrew Back Cover: step 2, image 1 of 2 Nokero N400 Back Cover Replacement, Unscrew Back Cover: step 2, image 2 of 2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Back Cover Replacement, Pry Open Back Cover: step 3, image 1 of 2 Nokero N400 Back Cover Replacement, Pry Open Back Cover: step 3, image 2 of 2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
Kasey Kolyno
125 Reputation
1 Guide authored
USF Tampa, Team 19-2, Blackwell Winter 2015 Member of USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 161
