Nokero N400 Switch Replacement
  1. Nokero N400 Switch Replacement, Remove Battery Cover: step 1, image 1 of 3 Nokero N400 Switch Replacement, Remove Battery Cover: step 1, image 2 of 3 Nokero N400 Switch Replacement, Remove Battery Cover: step 1, image 3 of 3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Switch Replacement, Unscrew Back Cover: step 2, image 1 of 2 Nokero N400 Switch Replacement, Unscrew Back Cover: step 2, image 2 of 2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Switch Replacement, Pry Open Back Cover: step 3, image 1 of 2 Nokero N400 Switch Replacement, Pry Open Back Cover: step 3, image 2 of 2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Switch Replacement, Remove Switch From Housing: step 4, image 1 of 1
    • Using a spudger carefully pry switch from housing.
  5. Nokero N400 Switch Replacement, Cut Old Switch Free: step 5, image 1 of 1
    • Use wire cutters to cut the two black wires attached to the old switch.
    • You must use a splicer or a soldering gun to reattach the wires of the new switch.
    • If you splice the new switch wires together in the opposite order of the old switch wires, the new switch will still work.
Benjamin franklin
101 Reputation
1 Guide authored
USF Tampa, Team 19-2, Blackwell Winter 2015 Member of USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 158
