Nokero SunRay Pro Power Panel Capacitor Replacement
  1. Nokero SunRay Pro Power Panel Capacitor Replacement, Front and Back Case: step 1, image 1 of 1
    • Turn over the device so that the back of the device is facing up.
  2. Nokero SunRay Pro Power Panel Capacitor Replacement: step 2, image 1 of 3 Nokero SunRay Pro Power Panel Capacitor Replacement: step 2, image 2 of 3 Nokero SunRay Pro Power Panel Capacitor Replacement: step 2, image 3 of 3
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
  3. Nokero SunRay Pro Power Panel Capacitor Replacement: step 3, image 1 of 2 Nokero SunRay Pro Power Panel Capacitor Replacement: step 3, image 2 of 2
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
  4. Nokero SunRay Pro Power Panel Capacitor Replacement: step 4, image 1 of 2 Nokero SunRay Pro Power Panel Capacitor Replacement: step 4, image 2 of 2
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
  5. Nokero SunRay Pro Power Panel Capacitor Replacement, Capacitor: step 5, image 1 of 1
    • Use the soldering station to desolder the two contact points around the connections of the capacitor to loosen the metal.
  6. Nokero SunRay Pro Power Panel Capacitor Replacement: step 6, image 1 of 1
    • Pull the capacitor through the circuit board to remove it.
Nicholas Orr
229 Reputation
2 Guides authored
USF Tampa, Team 9-3, Blackwell Winter 2015 Member of USF Tampa, Team 9-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G3
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 189
