Nokia 2115i Motherboard Replacement
  1. Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: step 1, image 1 of 3 Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: step 1, image 2 of 3 Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: step 1, image 3 of 3
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
  2. Nokia 2115i Motherboard Replacement: step 2, image 1 of 2 Nokia 2115i Motherboard Replacement: step 2, image 2 of 2
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
  3. Nokia 2115i Motherboard Replacement, Faceplate: step 3, image 1 of 3 Nokia 2115i Motherboard Replacement, Faceplate: step 3, image 2 of 3 Nokia 2115i Motherboard Replacement, Faceplate: step 3, image 3 of 3
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
  4. Nokia 2115i Motherboard Replacement, Removing the Keypad: step 4, image 1 of 2 Nokia 2115i Motherboard Replacement, Removing the Keypad: step 4, image 2 of 2
    • Note: The keypad will be loose and may fall off during this step.
    • Pull the face plate up and off of the phone.
    • To remove the keypad, simply lift it off the phone.
  5. Nokia 2115i Motherboard Replacement, Removing the Motherboard: step 5, image 1 of 2 Nokia 2115i Motherboard Replacement, Removing the Motherboard: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Locate the 6 screws on the metallic sheet that previously held the keypad. (This sheet, shown in the pictures, is the top side of the motherboard).
    • Note: 2 of the screws are on the bottom corners, 2 are on the right and left edges of the phone below the screen, and 2 are on the very top corners of the phone, above the screen.
    • Warning: The middle two screws are attached to the base of the phone with two black plastic rings. Use tweezers to remove the screws carefully to avoid breaking the plastic rings
    • Use a size T6 Torx screwdriver to remove each of these 6 screws.
  6. Nokia 2115i Motherboard Replacement: step 6, image 1 of 3 Nokia 2115i Motherboard Replacement: step 6, image 2 of 3 Nokia 2115i Motherboard Replacement: step 6, image 3 of 3
    • To remove the motherboard, lift it up and off the phone.
    • Note: The screen will still be attached to the motherboard.
Shane
80 Reputation
6 Guides authored
Cal Poly, Team 14-38, Forte Fall 2010 Member of Cal Poly, Team 14-38, Forte Fall 2010
CPSU-FORTE-F10S14G38
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 2,948
