Nokia 2610 Front Pannel Replacement
  1. Nokia 2610 Front Pannel Replacement, Battery and Sim Card: step 1, image 1 of 3 Nokia 2610 Front Pannel Replacement, Battery and Sim Card: step 1, image 2 of 3 Nokia 2610 Front Pannel Replacement, Battery and Sim Card: step 1, image 3 of 3
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Nokia 2610 Front Pannel Replacement: step 2, image 1 of 3 Nokia 2610 Front Pannel Replacement: step 2, image 2 of 3 Nokia 2610 Front Pannel Replacement: step 2, image 3 of 3
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Nokia 2610 Front Pannel Replacement: step 3, image 1 of 3 Nokia 2610 Front Pannel Replacement: step 3, image 2 of 3 Nokia 2610 Front Pannel Replacement: step 3, image 3 of 3
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  4. Nokia 2610 Front Pannel Replacement, Front Pannel: step 4, image 1 of 2 Nokia 2610 Front Pannel Replacement, Front Pannel: step 4, image 2 of 2
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  5. Nokia 2610 Front Pannel Replacement: step 5, image 1 of 2 Nokia 2610 Front Pannel Replacement: step 5, image 2 of 2
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
3 other people completed this guide.
Andrew Wood
336 Reputation
3 Guides authored
Cal Poly, Team 7-52, Amido Fall 2010 Member of Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 2,270
