Nokia 2610 Screen Replacement
  1. Nokia 2610 Screen Replacement, Battery and Sim Card: step 1, image 1 of 3 Nokia 2610 Screen Replacement, Battery and Sim Card: step 1, image 2 of 3 Nokia 2610 Screen Replacement, Battery and Sim Card: step 1, image 3 of 3
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Nokia 2610 Screen Replacement: step 2, image 1 of 3 Nokia 2610 Screen Replacement: step 2, image 2 of 3 Nokia 2610 Screen Replacement: step 2, image 3 of 3
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Nokia 2610 Screen Replacement: step 3, image 1 of 3 Nokia 2610 Screen Replacement: step 3, image 2 of 3 Nokia 2610 Screen Replacement: step 3, image 3 of 3
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  4. Nokia 2610 Screen Replacement, Front Pannel: step 4, image 1 of 2 Nokia 2610 Screen Replacement, Front Pannel: step 4, image 2 of 2
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  5. Nokia 2610 Screen Replacement: step 5, image 1 of 2 Nokia 2610 Screen Replacement: step 5, image 2 of 2
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
  6. Nokia 2610 Screen Replacement, Screen: step 6, image 1 of 1
    • Remove the 4 screws surrounding the screen using the precision T6 screwdriver.
  7. Nokia 2610 Screen Replacement: step 7, image 1 of 1
    • Lift the screen away from the phone and circuit board.
    • Warning: The screen is attached to the circuit board by a connector on the circuit board, so lift the screen straight up to avoid damage to the connector.
2 other people completed this guide.
Andrew Wood
336 Reputation
3 Guides authored
Cal Poly, Team 7-52, Amido Fall 2010 Member of Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
4 Members
12 Guides authored
1 Guide Comment
My Nokia 2610 dates from 2005 (or2006) and its screen was very scratched.
I bought a complete front cover replacement from vmobile.pl who were very efficient.
Andrew Wood’s instructions are crystal clear. The phone is as new now.
Many thanks. Andrew Boxall
Andrew - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 3,347
