Nokia 3120 Keypad Replacement
  1. Nokia 3120 Keypad Replacement, Battery Installation: step 1, image 1 of 3 Nokia 3120 Keypad Replacement, Battery Installation: step 1, image 2 of 3 Nokia 3120 Keypad Replacement, Battery Installation: step 1, image 3 of 3
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120 Keypad Replacement: step 2, image 1 of 1
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Nokia 3120 Keypad Replacement, Face Plate: step 3, image 1 of 3 Nokia 3120 Keypad Replacement, Face Plate: step 3, image 2 of 3 Nokia 3120 Keypad Replacement, Face Plate: step 3, image 3 of 3
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. Nokia 3120 Keypad Replacement, Keypad: step 4, image 1 of 1
    • Once the cover plate has been removed, the existing keypad should be easily removed.
    • To install a new keypad, simply place the new keypad in the same place where the old keypad was.
2 other people completed this guide.
Pierre Tong
92 Reputation
4 Guides authored
Clemson, Team 13-2, Benson Spring 2013 Member of Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 8
All Time: 885
