Nokia 3300B SD Card Replacement
  1. Nokia 3300B SD Card Replacement, Battery: step 1, image 1 of 2 Nokia 3300B SD Card Replacement, Battery: step 1, image 2 of 2
    • Flip the Nokia 3300B over with the back-side facing towards you.
    • Gently press the button on the back of the battery cover to release the cover and slide up.
  2. Nokia 3300B SD Card Replacement: step 2, image 1 of 2 Nokia 3300B SD Card Replacement: step 2, image 2 of 2
    • Lift the battery out of the back of the phone.
    • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
  3. Nokia 3300B SD Card Replacement, SD Card: step 3, image 1 of 3 Nokia 3300B SD Card Replacement, SD Card: step 3, image 2 of 3 Nokia 3300B SD Card Replacement, SD Card: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Using your finger, or a pair of tweezers, press down on the tab below the SD card.
    • The card will pop out of its case. Remove the card.
    • When placing the new SD card in the slot, it should "pop" in.
3 other people completed this guide.
George
91 Reputation
2 Guides authored
Cal Poly, Team 18-65, Johann Spring 2010 Member of Cal Poly, Team 18-65, Johann Spring 2010
CPSU-JOHANN-S10S18G65
4 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 2,833
