Nokia 3310 3G Frame Replacement
  1. Nokia 3310 3G Frame Replacement, Battery: step 1, image 1 of 2 Nokia 3310 3G Frame Replacement, Battery: step 1, image 2 of 2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Frame Replacement: step 2, image 1 of 2 Nokia 3310 3G Frame Replacement: step 2, image 2 of 2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Frame Replacement, Frame: step 3, image 1 of 3 Nokia 3310 3G Frame Replacement, Frame: step 3, image 2 of 3 Nokia 3310 3G Frame Replacement, Frame: step 3, image 3 of 3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
Taylor Lyford
732 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 1,009
