Nokia 3310 3G Keyboard Replacement
  1. Nokia 3310 3G Keyboard Replacement, Battery: step 1, image 1 of 2 Nokia 3310 3G Keyboard Replacement, Battery: step 1, image 2 of 2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Keyboard Replacement: step 2, image 1 of 2 Nokia 3310 3G Keyboard Replacement: step 2, image 2 of 2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Keyboard Replacement, Frame: step 3, image 1 of 3 Nokia 3310 3G Keyboard Replacement, Frame: step 3, image 2 of 3 Nokia 3310 3G Keyboard Replacement, Frame: step 3, image 3 of 3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Keyboard Replacement, Motherboard: step 4, image 1 of 3 Nokia 3310 3G Keyboard Replacement, Motherboard: step 4, image 2 of 3 Nokia 3310 3G Keyboard Replacement, Motherboard: step 4, image 3 of 3
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Keyboard Replacement, Keyboard: step 5, image 1 of 3 Nokia 3310 3G Keyboard Replacement, Keyboard: step 5, image 2 of 3 Nokia 3310 3G Keyboard Replacement, Keyboard: step 5, image 3 of 3
    • Using a spudger, unclip the bottom left snap to unplug the keyboard. The image shows the motherboard rotated 90 degrees counterclockwise
  6. Nokia 3310 3G Keyboard Replacement: step 6, image 1 of 1
    • Using your thumb, push the tab on the right side of the motherboard over to the right and then push downward to unclip the keyboard. It should fall away.
5 other people completed this guide.
Aaron LeBlanc
723 Reputation
5 Guides authored
One Comment
Very useful and to the point
OrangeShoe - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 44
All Time: 2,139
