Nokia 3360 Keypad Replacement
  1. Nokia 3360 Keypad Replacement, Battery: step 1, image 1 of 1
    • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Lift the back plate off the phone.
  2. Nokia 3360 Keypad Replacement: step 2, image 1 of 2 Nokia 3360 Keypad Replacement: step 2, image 2 of 2
    • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  3. Nokia 3360 Keypad Replacement: step 3, image 1 of 2 Nokia 3360 Keypad Replacement: step 3, image 2 of 2
    • Lift the battery out of the phone.
    • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
  4. Nokia 3360 Keypad Replacement, Cover Plate: step 4, image 1 of 2 Nokia 3360 Keypad Replacement, Cover Plate: step 4, image 2 of 2
    • Use finger nails of your thumbs to gently pull apart the face plate.
    • While the face plate is pulled apart, use index fingers to pull inner case towards you.
    • Separate faceplate and inner case.
  5. Nokia 3360 Keypad Replacement, Keypad: step 5, image 1 of 1
    • Gently peel up the edge of plastic keypad from the inside of the faceplate to remove.
3 other people completed this guide.
Travis Malmgren
69 Reputation
2 Guides authored
Cal Poly, Team 8-39, Regan Winter 2010 Member of Cal Poly, Team 8-39, Regan Winter 2010
CPSU-REGAN-W10S8G39
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 16
All Time: 3,734
