Nokia 5130 XpressMusic Logic Board / Casing Replacement
  1. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Sliding off the rear panel: step 1, image 1 of 1
    • Slide the rear panel in the indicated direction to unlock it.
  2. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Lifting up the rear panel: step 2, image 1 of 2 Nokia 5130 XpressMusic Logic Board / Casing Replacement, Lifting up the rear panel: step 2, image 2 of 2
    • After unlocking it, the rear panel can now be lifted up.
  3. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Rear screws: step 3, image 1 of 1
    • Remove the two T6 screws near the camera
  4. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Unclip the bezel: step 4, image 1 of 1
    • Unclip the several clips holding the front bezel in place
    • Be sure not to break off or damage the clips, otherwise the front bezel might no longer stay in place!
  5. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Keypad: step 5, image 1 of 1
    • Push in the pins holding in the keypad
  6. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Remove the keypad: step 6, image 1 of 1
    • The keypad can now be removed.
  7. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Remove the remaining parts: step 7, image 1 of 1
    • Lift up the logic board / display and remove it from the case.
iSzymon
600 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 394
