Nokia 515 Front cover and keypad replacement
  1. Nokia 515 Front cover and keypad replacement, Front cover and keypad: step 1, image 1 of 1
    • Remove the back cover with your fingers or with the eject tool which is included by Nokia.
    • Don't forget to turn off your device!
  2. Nokia 515 Front cover and keypad replacement: step 2, image 1 of 1
    • Remove the battery, the microSD card and the SIM card.
  3. Nokia 515 Front cover and keypad replacement: step 3, image 1 of 1
    • Remove the 2 screws with the T4 screwdriver.
    • Please store the screws on a safe place! I already lost a screw!
  4. Nokia 515 Front cover and keypad replacement: step 4, image 1 of 2 Nokia 515 Front cover and keypad replacement: step 4, image 2 of 2
    • Take the metal spudger and pry it firmly under the plastic hinges.
    • Although you want to replace the cover, be very careful by doing it! You could harm yourself with the metal spudger.
    • You could also use your fingers instead of the spudger to do it!
  5. Nokia 515 Front cover and keypad replacement, Remove the keypad: step 5, image 1 of 3 Nokia 515 Front cover and keypad replacement, Remove the keypad: step 5, image 2 of 3 Nokia 515 Front cover and keypad replacement, Remove the keypad: step 5, image 3 of 3
    • To remove the keypad, you should use the spudger to push the top clamps down a little bit while pressing your fingers against the inside of the keypad.
    • The keypad should be loose at the top.
    • To remove the bottom, just use a little bit of force to pull it off the front panel.
    • Just use a little bit of force.
  6. Nokia 515 Front cover and keypad replacement: step 6, image 1 of 1
    • To assemble the new keypad, start at the upper half of the keyboard.
  7. Nokia 515 Front cover and keypad replacement: step 7, image 1 of 3 Nokia 515 Front cover and keypad replacement: step 7, image 2 of 3 Nokia 515 Front cover and keypad replacement: step 7, image 3 of 3
    • To reassemble the front, just click it in place (you hear a clicking noise).
    • Now screw the T4 screws back into the holes.
    • Now you put the microSD card, the SIM card and the battery back into your device.
    • Now you can turn on your device.
You did it!
3 other people completed this guide.
Special thanks to these translators:
de en
100%
Leon is helping us fix the world! Want to contribute?
Start translating ›
Leon
376 Reputation
1 Guide authored
One Comment
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 33
All Time: 859
