Nokia 5165 Motherboard Replacement
  1. Nokia 5165 Motherboard Replacement, Removing The Battery: step 1, image 1 of 3 Nokia 5165 Motherboard Replacement, Removing The Battery: step 1, image 2 of 3 Nokia 5165 Motherboard Replacement, Removing The Battery: step 1, image 3 of 3
    • Remove the battery by pushing the button and sliding the battery out a bit then pulling it out
  2. Nokia 5165 Motherboard Replacement, Removing The Front Cover: step 2, image 1 of 2 Nokia 5165 Motherboard Replacement, Removing The Front Cover: step 2, image 2 of 2
    • Find the tab at the top of the phone and press down with your fingernail or the flat end of a spudger
    • The top of the cover should pop out and then pull the top part out and the whole thing should come off
  3. Nokia 5165 Motherboard Replacement, Removing The Motherboard: step 3, image 1 of 3 Nokia 5165 Motherboard Replacement, Removing The Motherboard: step 3, image 2 of 3 Nokia 5165 Motherboard Replacement, Removing The Motherboard: step 3, image 3 of 3
    • Remove these screws
    • 4 T6 Torx Screws
    • Lift up the white cover
  4. Nokia 5165 Motherboard Replacement: step 4, image 1 of 2 Nokia 5165 Motherboard Replacement: step 4, image 2 of 2
    • 2 T6 Torx screws
    • Lift up the screen and number pad assembly
  5. Nokia 5165 Motherboard Replacement: step 5, image 1 of 1
    • Pull out the motherboard
Ethan Pikscher
351 Reputation
3 Guides authored
Kid fixers Member of Kid fixers
Community
172 Members
229 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 151
