Nokia 5310b XpressMusic Keypad Replacement
  1. Nokia 5310b XpressMusic Keypad Replacement, Battery: step 1, image 1 of 1
    • Slide the back cover down with your thumb.
    • *Note: the battery cover is not shown in this picture
  2. Nokia 5310b XpressMusic Keypad Replacement: step 2, image 1 of 2 Nokia 5310b XpressMusic Keypad Replacement: step 2, image 2 of 2
    • Gently lift the battery with a fingernail and remove it from its housing.
    • *Note: the battery may be replaced or repaired at this step
  3. Nokia 5310b XpressMusic Keypad Replacement, Keypad: step 3, image 1 of 3 Nokia 5310b XpressMusic Keypad Replacement, Keypad: step 3, image 2 of 3 Nokia 5310b XpressMusic Keypad Replacement, Keypad: step 3, image 3 of 3
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 FIRST to remove the camera cover and two T6 screws, before removing the faceplate.
    • Use the Spudger to gently pry up the edges of the front face plate
    • At the center of the faceplate edge below the music keys there is a small latch on each side.
  4. Nokia 5310b XpressMusic Keypad Replacement: step 4, image 1 of 2 Nokia 5310b XpressMusic Keypad Replacement: step 4, image 2 of 2
    • Lift up the keypad from the bottom with either the spudger or your finger.
    • Note: at this time the keypad can be removed and replaced
5 other people completed this guide.
Max Kirby
518 Reputation
4 Guides authored
Cal Poly, Team 15-14, Regan Spring 2011 Member of Cal Poly, Team 15-14, Regan Spring 2011
CPSU-REGAN-S11S15G14
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 6,036
