Nokia 6010 Keypad Replacement
  1. Nokia 6010 Keypad Replacement, Battery: step 1, image 1 of 3 Nokia 6010 Keypad Replacement, Battery: step 1, image 2 of 3 Nokia 6010 Keypad Replacement, Battery: step 1, image 3 of 3
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
  2. Nokia 6010 Keypad Replacement: step 2, image 1 of 2 Nokia 6010 Keypad Replacement: step 2, image 2 of 2
    • Lift the battery near the bottom and pry up.
  3. Nokia 6010 Keypad Replacement, SIM Card: step 3, image 1 of 1
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
  4. Nokia 6010 Keypad Replacement, Keypad: step 4, image 1 of 2 Nokia 6010 Keypad Replacement, Keypad: step 4, image 2 of 2
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
  5. Nokia 6010 Keypad Replacement: step 5, image 1 of 1
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
2 other people completed this guide.
Nicholas Hanne
129 Reputation
8 Guides authored
Cal Poly, Team 14-45, Regan Winter 2010 Member of Cal Poly, Team 14-45, Regan Winter 2010
CPSU-REGAN-W10S14G45
5 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 21
All Time: 3,194
