Nokia 6030 LCD Screen Replacement
  1. Nokia 6030 LCD Screen Replacement, Battery: step 1, image 1 of 3 Nokia 6030 LCD Screen Replacement, Battery: step 1, image 2 of 3 Nokia 6030 LCD Screen Replacement, Battery: step 1, image 3 of 3
    • Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
  2. Nokia 6030 LCD Screen Replacement: step 2, image 1 of 3 Nokia 6030 LCD Screen Replacement: step 2, image 2 of 3 Nokia 6030 LCD Screen Replacement: step 2, image 3 of 3
    • Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
    • Lift out battery and remove.
  3. Nokia 6030 LCD Screen Replacement, SIM Card: step 3, image 1 of 3 Nokia 6030 LCD Screen Replacement, SIM Card: step 3, image 2 of 3 Nokia 6030 LCD Screen Replacement, SIM Card: step 3, image 3 of 3
    • Use your finger to lift the metal cage up.
    • Remove SIM card.
  4. Nokia 6030 LCD Screen Replacement: step 4, image 1 of 1
    • Use your finger to close the metal cage.
  5. Nokia 6030 LCD Screen Replacement, Front Cover: step 5, image 1 of 3 Nokia 6030 LCD Screen Replacement, Front Cover: step 5, image 2 of 3 Nokia 6030 LCD Screen Replacement, Front Cover: step 5, image 3 of 3
    • Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
  6. Nokia 6030 LCD Screen Replacement: step 6, image 1 of 2 Nokia 6030 LCD Screen Replacement: step 6, image 2 of 2
    • After removing the top cover, turn the phone over so the screen is facing upwards.
  7. Nokia 6030 LCD Screen Replacement: step 7, image 1 of 3 Nokia 6030 LCD Screen Replacement: step 7, image 2 of 3 Nokia 6030 LCD Screen Replacement: step 7, image 3 of 3
    • Use your fingers to slowly lift the screen back towards the bottom of the phone using the arrows found at the top of the phone.
  8. Nokia 6030 LCD Screen Replacement, LCD Screen: step 8, image 1 of 3 Nokia 6030 LCD Screen Replacement, LCD Screen: step 8, image 2 of 3 Nokia 6030 LCD Screen Replacement, LCD Screen: step 8, image 3 of 3
    • Remove the six screws found along the frame of the phone with a T6 Torx screwdriver and put them to the side.
  9. Nokia 6030 LCD Screen Replacement: step 9, image 1 of 3 Nokia 6030 LCD Screen Replacement: step 9, image 2 of 3 Nokia 6030 LCD Screen Replacement: step 9, image 3 of 3
    • Gently lift the top of the screen up.
    • Be cautious of loose parts.
  10. Nokia 6030 LCD Screen Replacement: step 10, image 1 of 3 Nokia 6030 LCD Screen Replacement: step 10, image 2 of 3 Nokia 6030 LCD Screen Replacement: step 10, image 3 of 3
    • Gently pull up on the grey plastic tab.
2 other people completed this guide.
Spencer Woodworth
316 Reputation
9 Guides authored
Cal Poly, Team 23-63, Johann Spring 2010 Member of Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Members
17 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 7,140
