Nokia 6085h Keypad Replacement
  1. Nokia 6085h Keypad Replacement, Battery: step 1, image 1 of 1
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
  2. Nokia 6085h Keypad Replacement: step 2, image 1 of 1
    • Remove the phone's battery.
  3. Nokia 6085h Keypad Replacement, Motherboard: step 3, image 1 of 2 Nokia 6085h Keypad Replacement, Motherboard: step 3, image 2 of 2
    • Use the iFixit opening tool to pry out the two tabs at the top corners of the battery compartment.
  4. Nokia 6085h Keypad Replacement: step 4, image 1 of 1
    • Gently pull off the hinge cap from the top of the phone by hand.
  5. Nokia 6085h Keypad Replacement: step 5, image 1 of 1
    • Use a T6 Torx screwdriver to remove the four 7.6 mm screws at the corners of the battery compartment.
  6. Nokia 6085h Keypad Replacement: step 6, image 1 of 2 Nokia 6085h Keypad Replacement: step 6, image 2 of 2
    • Open the phone and turn it on its side. You will see a seam around the Nokia’s side.
    • Use the iFixit opening tool to run along this seam to pop the clips holding the casing to the frame.
  7. Nokia 6085h Keypad Replacement: step 7, image 1 of 1
    • Use your hand to gently pull off the back panel from the bottom half of the phone.
  8. Nokia 6085h Keypad Replacement: step 8, image 1 of 1
    • Close the phone and place it on a flat surface.
    • Use the plastic opening tool or your finger to lift up the motherboard from the bottom casing.
    • Be careful when pulling up the board; there is still a ribbon cable attached to the back of the board.
  9. Nokia 6085h Keypad Replacement: step 9, image 1 of 1
    • Find the underside of the motherboard and locate the ribbon cable that attaches the board to the rest of the phone. Use the plastic opening tool to slowly detach the ribbon cable connector, then pull the motherboard away from the frame.
  10. Nokia 6085h Keypad Replacement, Keypad: step 10, image 1 of 1
    • Pry the keypad out with the plastic opening tool once the motherboard is moved out of the way.
Andrew
397 Reputation
4 Guides authored
Cal Poly, Team 4-46, Amido Fall 2010 Member of Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 2,357
