Nokia 6085h Speaker Replacement
  1. Nokia 6085h Speaker Replacement, Battery: step 1, image 1 of 1
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
  2. Nokia 6085h Speaker Replacement: step 2, image 1 of 1
    • Remove the phone's battery.
  3. Nokia 6085h Speaker Replacement, Front LCD Display: step 3, image 1 of 3 Nokia 6085h Speaker Replacement, Front LCD Display: step 3, image 2 of 3 Nokia 6085h Speaker Replacement, Front LCD Display: step 3, image 3 of 3
    • With the phone closed, run a plastic opening tool along the seam of the top half of the phone.
    • Make sure to disconnect each of the five clips before proceeding to the next step.
    • There are two clips on each side of the phone and one on the top.
  4. Nokia 6085h Speaker Replacement: step 4, image 1 of 2 Nokia 6085h Speaker Replacement: step 4, image 2 of 2
    • Remove the four 3.2 mm screws from the front panel using a T6 Torx screwdriver.
    • The fourth screw is located under a fold in the ribbon cable.
  5. Nokia 6085h Speaker Replacement: step 5, image 1 of 3 Nokia 6085h Speaker Replacement: step 5, image 2 of 3 Nokia 6085h Speaker Replacement: step 5, image 3 of 3
    • Starting in the lower right corner, slowly begin to lift the tape that is holding down the front LCD and cables.
    • Be careful around the two ribbon cables attached to the tape. These cables are fragile.
    • Lift the tape from the board.
  6. Nokia 6085h Speaker Replacement: step 6, image 1 of 1
    • Using a plastic opening tool, lift the ribbon cable connection below the front LCD.
  7. Nokia 6085h Speaker Replacement: step 7, image 1 of 3 Nokia 6085h Speaker Replacement: step 7, image 2 of 3 Nokia 6085h Speaker Replacement: step 7, image 3 of 3
    • Using a plastic opening tool, slowly pry the LCD display from the bottom, releasing it from the glue that is holding it to the board.
  8. Nokia 6085h Speaker Replacement, Inner LCD Display: step 8, image 1 of 1
    • Locate the ribbon cable connection in the upper right hand corner of the board.
    • Using a plastic opening tool, lift off the cable from the board.
    • Be gentle and make sure not to rip the ribbon cable.
  9. Nokia 6085h Speaker Replacement: step 9, image 1 of 2 Nokia 6085h Speaker Replacement: step 9, image 2 of 2
    • Using a plastic opening tool, slowly work the board off the mounts holding it to the frame.
    • Flip the board over to reveal the main display.
  10. Nokia 6085h Speaker Replacement: step 10, image 1 of 1
    • Locate the ribbon cable for the main display on the bottom of the board.
    • Slowly lift off the ribbon connector from its housing using a plastic opening tool.
  11. Nokia 6085h Speaker Replacement: step 11, image 1 of 2 Nokia 6085h Speaker Replacement: step 11, image 2 of 2
    • Slowly wedge the plastic opening tool under the bottom of the main display.
    • Separate the display from the glue lifting it off the board.
  12. Nokia 6085h Speaker Replacement, Speaker: step 12, image 1 of 1
    • Using a case opening tool, gently pry the speaker in the bottom corner from the glue from right to left until it pops out.
Andrew
397 Reputation
4 Guides authored
Cal Poly, Team 4-46, Amido Fall 2010 Member of Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 594
