Nokia 6086 Keypad Replacement
  1. Nokia 6086 Keypad Replacement, Battery: step 1, image 1 of 1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Nokia 6086 Keypad Replacement: step 2, image 1 of 3 Nokia 6086 Keypad Replacement: step 2, image 2 of 3 Nokia 6086 Keypad Replacement: step 2, image 3 of 3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Nokia 6086 Keypad Replacement: step 3, image 1 of 3 Nokia 6086 Keypad Replacement: step 3, image 2 of 3 Nokia 6086 Keypad Replacement: step 3, image 3 of 3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. Nokia 6086 Keypad Replacement, Upper Back Cover: step 4, image 1 of 1
    • Turn the phone so that the back of the phone is facing forward.
    • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
  5. Nokia 6086 Keypad Replacement: step 5, image 1 of 2 Nokia 6086 Keypad Replacement: step 5, image 2 of 2
    • Place the iPod opening tool under the tabs near the top of the phone.
    • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
    • Repeat for the left and the right sides.
  6. Nokia 6086 Keypad Replacement: step 6, image 1 of 2 Nokia 6086 Keypad Replacement: step 6, image 2 of 2
    • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
    • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
  7. Nokia 6086 Keypad Replacement: step 7, image 1 of 3 Nokia 6086 Keypad Replacement: step 7, image 2 of 3 Nokia 6086 Keypad Replacement: step 7, image 3 of 3
    • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
  8. Nokia 6086 Keypad Replacement, Base of The Phone: step 8, image 1 of 2 Nokia 6086 Keypad Replacement, Base of The Phone: step 8, image 2 of 2
    • Locate the four screws.
    • Remove the screws using a T6 Torx screwdriver.
  9. Nokia 6086 Keypad Replacement: step 9, image 1 of 2 Nokia 6086 Keypad Replacement: step 9, image 2 of 2
    • Turn the phone over.
    • Gently pull apart the phone.
    • Start at the bottom of the phone and pull outward.
    • There are plastic catches on the middle of each side. These should pop free as you pull.
    • Be careful, the phone will separate into two sections.
  10. Nokia 6086 Keypad Replacement: step 10, image 1 of 2 Nokia 6086 Keypad Replacement: step 10, image 2 of 2
    • The phone should now be in two different sections.
    • 1) The logic board and the back cover
    • 2) The keypad and the rest of the phone
  11. Nokia 6086 Keypad Replacement, Keypad: step 11, image 1 of 1
    • Place the keypad in view.
  12. Nokia 6086 Keypad Replacement: step 12, image 1 of 2 Nokia 6086 Keypad Replacement: step 12, image 2 of 2
    • Remove the keypad from the phone by lifting the keypad off the phone.
  13. Nokia 6086 Keypad Replacement: step 13, image 1 of 1
    • The keypad should be detached.
Caitlin Rahm
78 Reputation
4 Guides authored
Cal Poly, Team 26-30, Regan Spring 2010 Member of Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 1,299
