Introduction
Use this guide to replace the display screen of the Nokia 6350-1b cellphone.
Using an iFixit opening tool, separate the plastic frame and the rest of the phone.
Move the opening tool along the frame, unlocking all of the locks that keep the frame in place.
Remove the plastic frame and set aside.
Using a T-5 screw driver, unscrew the screws on the four corners of the phone.
Using an opening tool, pry between the screen cover (top left) and the phone frame (top right).
To separate, unlock the various groove-like locks on all four sides of the phone.
Carefully remove the screen cover (top left) to reveal the logic board (bottom).
1 Guide Comment
Hi
Thanks for putting these together. I have a flip phone 6350 and I love it. Every time one stops functioning I get another one used. But I often have problems with the charging ports. The connection gets wonky and only works when I move the plug around in the socket of the phone. Can these be easily replaced? fixed? I even tried using a universal charger and charged the batteries in that, but then the battery connections stopped working.
thanks!
Annemarie
