Nokia 6560 Speaker Replacement
Introduction
Go to step 1This guide shows you how to replace the speakers on your Nokia 6560.
Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
Lift off your cell phone's back cover.
Use your index finger to first push down and then lift up the battery as shown.
Remove the battery from your cell phone.
Open the front cover of your cell phone with the plastic opening tool or finger nail.
Lift the cover upwards, starting from the bottom below the keypad.
Use the plastic opening tool to unmount the thin metal frame at the tab connections. You must do this on both sides.
Lift the thin metal frame off of the plastic frame.
Pull the sides of the plastic frame apart in order to loosen the display.
Take the display out of the plastic frame.
Now you have the bare plastic frame that holds the speaker.
The microphone is held at the bottom of this frame.
Neither the speaker nor the microphone can be repaired. You must replace the whole frame.
