Nokia 6590i Logic Board Replacement
  1. Nokia 6590i Logic Board Replacement, Battery: step 1, image 1 of 2 Nokia 6590i Logic Board Replacement, Battery: step 1, image 2 of 2
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Nokia 6590i Logic Board Replacement: step 2, image 1 of 1
    • To remove the battery, push it down from the top and pull it out.
  3. Nokia 6590i Logic Board Replacement, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: step 3, image 1 of 1
    • Grip the front cover from the bottom.
  4. Nokia 6590i Logic Board Replacement: step 4, image 1 of 1
    • Lift the front cover off.
  5. Nokia 6590i Logic Board Replacement: step 5, image 1 of 1
    • Remove the six screws using a T6 torx screwdriver.
  6. Nokia 6590i Logic Board Replacement: step 6, image 1 of 1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Nokia 6590i Logic Board Replacement: step 7, image 1 of 1
    • Remove assembly from phone
  8. Nokia 6590i Logic Board Replacement, Logic Board: step 8, image 1 of 1
    • The logic board now sits on top of the phone.
  9. Nokia 6590i Logic Board Replacement: step 9, image 1 of 1
    • Lift the logic board out of the phone.
Colby Leslie
1 Reputation
7 Guides authored
Cal Poly, Team 22-3, Maness Fall 2010 Member of Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,092
