Nokia 6590i Speaker Replacement
  1. Nokia 6590i Speaker Replacement, Battery: step 1, image 1 of 2 Nokia 6590i Speaker Replacement, Battery: step 1, image 2 of 2
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Nokia 6590i Speaker Replacement: step 2, image 1 of 1
    • To remove the battery, push it down from the top and pull it out.
  3. Nokia 6590i Speaker Replacement, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: step 3, image 1 of 1
    • Grip the front cover from the bottom.
  4. Nokia 6590i Speaker Replacement: step 4, image 1 of 1
    • Lift the front cover off.
  5. Nokia 6590i Speaker Replacement: step 5, image 1 of 1
    • Remove the six screws using a T6 torx screwdriver.
  6. Nokia 6590i Speaker Replacement: step 6, image 1 of 1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Nokia 6590i Speaker Replacement: step 7, image 1 of 1
    • Remove assembly from phone
  8. Nokia 6590i Speaker Replacement, Speaker: step 8, image 1 of 1
    • Flip assembly over
  9. Nokia 6590i Speaker Replacement: step 9, image 1 of 1
    • Locate speaker on the back of the assembly.
  10. Nokia 6590i Speaker Replacement: step 10, image 1 of 1
    • Insert spudger under upper left side of speaker and gently lift to remove
  11. Nokia 6590i Speaker Replacement: step 11, image 1 of 1
    • Remove speaker.
Colby Leslie
1 Reputation
7 Guides authored
Cal Poly, Team 22-3, Maness Fall 2010 Member of Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 764
