Nokia 8290 Antenna Replacement
  1. Nokia 8290 Antenna Replacement, Front Cover: step 1, image 1 of 3 Nokia 8290 Antenna Replacement, Front Cover: step 1, image 2 of 3 Nokia 8290 Antenna Replacement, Front Cover: step 1, image 3 of 3
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Nokia 8290 Antenna Replacement, Antenna: step 2, image 1 of 3 Nokia 8290 Antenna Replacement, Antenna: step 2, image 2 of 3 Nokia 8290 Antenna Replacement, Antenna: step 2, image 3 of 3
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. Nokia 8290 Antenna Replacement: step 3, image 1 of 3 Nokia 8290 Antenna Replacement: step 3, image 2 of 3 Nokia 8290 Antenna Replacement: step 3, image 3 of 3
    • After removing the circuit board/faceplate sub-assembly, locate the antenna.
    • Remove the antenna by prying it out with your fingers or a prying tool. It may help to turn the back portion of the phone over to allow the antenna to fall away.
Austin Culberson
87 Reputation
5 Guides authored
Clemson, Team 15-3, Benson Fall 2012 Member of Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 Members
21 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 510
