Nokia 8290 Microphone Replacement
  1. Nokia 8290 Microphone Replacement, Front Cover: step 1, image 1 of 3 Nokia 8290 Microphone Replacement, Front Cover: step 1, image 2 of 3 Nokia 8290 Microphone Replacement, Front Cover: step 1, image 3 of 3
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Nokia 8290 Microphone Replacement, Circuit Board: step 2, image 1 of 3 Nokia 8290 Microphone Replacement, Circuit Board: step 2, image 2 of 3 Nokia 8290 Microphone Replacement, Circuit Board: step 2, image 3 of 3
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. Nokia 8290 Microphone Replacement: step 3, image 1 of 3 Nokia 8290 Microphone Replacement: step 3, image 2 of 3 Nokia 8290 Microphone Replacement: step 3, image 3 of 3
    • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
    • Rotate the faceplate away from the circuit board.
    • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
  4. Nokia 8290 Microphone Replacement, Microphone: step 4, image 1 of 3 Nokia 8290 Microphone Replacement, Microphone: step 4, image 2 of 3 Nokia 8290 Microphone Replacement, Microphone: step 4, image 3 of 3
    • Use the spudger to peel back the top-left corner of the white adhesive film. This can be done by working the spudger back and forth underneath the film.
  5. Nokia 8290 Microphone Replacement: step 5, image 1 of 3 Nokia 8290 Microphone Replacement: step 5, image 2 of 3 Nokia 8290 Microphone Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Continue to peel the film back until you can see the microphone.
    • Use tweezers to remove the microphone.
Parker Niebauer
7 Reputation
6 Guides authored
Clemson, Team 15-3, Benson Fall 2012 Member of Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 Members
22 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 449
