Nokia 8390 Charging Port Replacement
  1. Nokia 8390 Charging Port Replacement, Back Cover: step 1, image 1 of 1
    • Locate the button on the bottom of the back cover.
  2. Nokia 8390 Charging Port Replacement: step 2, image 1 of 3 Nokia 8390 Charging Port Replacement: step 2, image 2 of 3 Nokia 8390 Charging Port Replacement: step 2, image 3 of 3
    • Depress the button with your finger.
    • While the button is depressed, slide the back cover off of the phone.
  3. Nokia 8390 Charging Port Replacement, Outer Case: step 3, image 1 of 3 Nokia 8390 Charging Port Replacement, Outer Case: step 3, image 2 of 3 Nokia 8390 Charging Port Replacement, Outer Case: step 3, image 3 of 3
    • Grasp the top and bottom of the front cover.
    • Grasp the phone body with your other hand.
    • Lightly pull the casing off of the phone.
  4. Nokia 8390 Charging Port Replacement, Motherboard: step 4, image 1 of 3 Nokia 8390 Charging Port Replacement, Motherboard: step 4, image 2 of 3 Nokia 8390 Charging Port Replacement, Motherboard: step 4, image 3 of 3
    • Locate the six star-shaped screws on the phone.
    • Note: There are two on the bottom end, two in the middle, and two on the top end.
    • Remove these screws using the screwdriver.
  5. Nokia 8390 Charging Port Replacement: step 5, image 1 of 3 Nokia 8390 Charging Port Replacement: step 5, image 2 of 3 Nokia 8390 Charging Port Replacement: step 5, image 3 of 3
    • Grab the top and bottom of the phone casing.
    • Carefully pull the motherboard apart from the bottom casing.
    • The circuit board should be divided into two parts.
  6. Nokia 8390 Charging Port Replacement: step 6, image 1 of 3 Nokia 8390 Charging Port Replacement: step 6, image 2 of 3 Nokia 8390 Charging Port Replacement: step 6, image 3 of 3
    • Grab the top and bottom of the remaining casing.
    • Carefully pull apart the casing from the circuit board.
  7. Nokia 8390 Charging Port Replacement: step 7, image 1 of 1
    • The circuit board should be divided into three parts, completely separate from the back casing, as shown.
  8. Nokia 8390 Charging Port Replacement, Charging Port: step 8, image 1 of 3 Nokia 8390 Charging Port Replacement, Charging Port: step 8, image 2 of 3 Nokia 8390 Charging Port Replacement, Charging Port: step 8, image 3 of 3
    • Hold back of phone in hand so that hand is not covering any parts.
    • Grasp charge port with thumb.
    • Pull out with hand.
2 other people completed this guide.
Clinton
57 Reputation
7 Guides authored
Clemson, Team 14-5, Benson Fall 2012 Member of Clemson, Team 14-5, Benson Fall 2012
CLEM-BENSON-F12S14G5
3 Members
21 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 360
