Nokia Asha 201 Audio Jack Replacement
  1. Nokia Asha 201 Audio Jack Replacement, Audio Jack: step 1, image 1 of 1
    • Remove the white case by popping apart the front and back with your finger.
  2. Nokia Asha 201 Audio Jack Replacement: step 2, image 1 of 1
    • Remove the battery by taking it out with your fingers.
  3. Nokia Asha 201 Audio Jack Replacement: step 3, image 1 of 1
    • Remove the two 5.5mm screws by using the T6 screwdriver.
  4. Nokia Asha 201 Audio Jack Replacement: step 4, image 1 of 1
    • Use the blue plastic opening tool to remove the front of the white case.
  5. Nokia Asha 201 Audio Jack Replacement: step 5, image 1 of 1
    • Remove the keyboard using your fingers and set aside.
  6. Nokia Asha 201 Audio Jack Replacement: step 6, image 1 of 1
    • Unscrew the two 5.5mm screws near the bottom of the device on either side using the T6 screwdriver.
  7. Nokia Asha 201 Audio Jack Replacement: step 7, image 1 of 1
    • Separate the black plastic internal case from the screen by prying with the blue plastic opening tool.
  8. Nokia Asha 201 Audio Jack Replacement: step 8, image 1 of 1
    • The black plastic cover should now be separated from the motherboard. Replace the audio jack by removing it with your fingers.
Betsy Walker
157 Reputation
1 Guide authored
USF Tampa, Team S1-G3, Leahy Fall 2019 Member of USF Tampa, Team S1-G3, Leahy Fall 2019
USFT-LEAHY-F19S1G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 195
