Nokia Classic 2600c-2b Battery Replacement
  1. Nokia Classic 2600c-2b Battery Replacement, Battery: step 1, image 1 of 2 Nokia Classic 2600c-2b Battery Replacement, Battery: step 1, image 2 of 2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Nokia Classic 2600c-2b Battery Replacement: step 2, image 1 of 1
    • Remove the back cover to expose the battery.
  3. Nokia Classic 2600c-2b Battery Replacement: step 3, image 1 of 2 Nokia Classic 2600c-2b Battery Replacement: step 3, image 2 of 2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
    • Follow the instructions in reverse order to reassemble the phone.
Ian VanZandt
654 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 731
