Nokia Classic 2600c-2b Display Screen Replacement
  1. Nokia Classic 2600c-2b Display Screen Replacement, Replacing Display Screen: step 1, image 1 of 2 Nokia Classic 2600c-2b Display Screen Replacement, Replacing Display Screen: step 1, image 2 of 2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Nokia Classic 2600c-2b Display Screen Replacement: step 2, image 1 of 1
    • Remove the back cover to expose the battery.
  3. Nokia Classic 2600c-2b Display Screen Replacement: step 3, image 1 of 2 Nokia Classic 2600c-2b Display Screen Replacement: step 3, image 2 of 2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
  4. Nokia Classic 2600c-2b Display Screen Replacement: step 4, image 1 of 2 Nokia Classic 2600c-2b Display Screen Replacement: step 4, image 2 of 2
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
  5. Nokia Classic 2600c-2b Display Screen Replacement: step 5, image 1 of 1
    • Remove the faceplate with the number pad attached.
  6. Nokia Classic 2600c-2b Display Screen Replacement: step 6, image 1 of 1
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
  7. Nokia Classic 2600c-2b Display Screen Replacement: step 7, image 1 of 2 Nokia Classic 2600c-2b Display Screen Replacement: step 7, image 2 of 2
    • Locate the six screws positions along the edges of the motherboard.
    • Unscrew the six screws using the Torx 5 screwdriver (see Introduction for description of a Torx 5 screwdriver).
    • CAUTION! Place the screws in a secure location.
  8. Nokia Classic 2600c-2b Display Screen Replacement: step 8, image 1 of 2 Nokia Classic 2600c-2b Display Screen Replacement: step 8, image 2 of 2
    • Locate the orange ribbon tape connecting the metal display plate to the motherboard.
    • Lift the black latch attaching the tape to the motherboard.
    • Gently pull the tape out of the latch slot to remove the metal display.
  9. Nokia Classic 2600c-2b Display Screen Replacement: step 9, image 1 of 2 Nokia Classic 2600c-2b Display Screen Replacement: step 9, image 2 of 2
    • Using the plastic opening tool, gently pry off the motherboard from the plastic shell.
    • CAUTION! When pulling the motherboard out, be careful not to damage the battery under the lower left hand corner of the motherboard.
  10. Nokia Classic 2600c-2b Display Screen Replacement: step 10, image 1 of 1
    • Gently pull the orange ribbon tape up to remove the display.
    • Replace display screen.
    • Follow the instructions in reverse order to reassemble the phone.
2 other people completed this guide.
Ian VanZandt
675 Reputation
5 Guides authored
3 Comments
Pretty accurate, nice guide! Easily repaired and it works!
Dominik Fryč - Reply
Where can I find the screen?
jackie fincher -
Perfect guide! But Where can i get original components??
Navin Singh - Reply
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 12
All Time: 1,006
