Nokia Classic 2600c-2b Motherboard Replacement
  1. Nokia Classic 2600c-2b Motherboard Replacement, Motherboard: step 1, image 1 of 2 Nokia Classic 2600c-2b Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Nokia Classic 2600c-2b Motherboard Replacement: step 2, image 1 of 1
    • Remove the back cover to expose the battery.
  3. Nokia Classic 2600c-2b Motherboard Replacement: step 3, image 1 of 2 Nokia Classic 2600c-2b Motherboard Replacement: step 3, image 2 of 2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
  4. Nokia Classic 2600c-2b Motherboard Replacement: step 4, image 1 of 2 Nokia Classic 2600c-2b Motherboard Replacement: step 4, image 2 of 2
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • Note: Some force is required
  5. Nokia Classic 2600c-2b Motherboard Replacement: step 5, image 1 of 1
    • Remove the faceplate with the number pad attached.
  6. Nokia Classic 2600c-2b Motherboard Replacement: step 6, image 1 of 1
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
  7. Nokia Classic 2600c-2b Motherboard Replacement: step 7, image 1 of 2 Nokia Classic 2600c-2b Motherboard Replacement: step 7, image 2 of 2
    • Locate the six screws positions along the edges of the motherboard.
    • Unscrew the six screws using the Torx 5 screwdriver (see Introduction for description of a Torx 5 screwdriver).
    • CAUTION! Place the screws in a secure location.
  8. Nokia Classic 2600c-2b Motherboard Replacement: step 8, image 1 of 2 Nokia Classic 2600c-2b Motherboard Replacement: step 8, image 2 of 2
    • Locate the orange ribbon tape connecting the metal display plate to the motherboard.
    • Lift the black latch attaching the tape to the motherboard.
    • Gently pull the tape out of the latch slot to remove the metal display.
  9. Nokia Classic 2600c-2b Motherboard Replacement: step 9, image 1 of 2 Nokia Classic 2600c-2b Motherboard Replacement: step 9, image 2 of 2
    • Using the plastic opening tool, gently pry off the motherboard from the plastic shell.
    • CAUTION! When pulling the motherboard out, be careful not to damage the battery under the lower left hand corner of the motherboard.
  10. Nokia Classic 2600c-2b Motherboard Replacement: step 10, image 1 of 1
    • Turn the motherboard over and locate the orange ribbon tape connecting the display to the motherboard.
    • Gently pull the tape up to remove the display.
    • Replace the old motherboard with the new motherboard.
    • Follow the directions in reverse order to reassemble the phone.
Ian VanZandt
654 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 658
