Nokia E61i Front Cover Replacement
  1. Nokia E61i Front Cover Replacement, Battery: step 1, image 1 of 2 Nokia E61i Front Cover Replacement, Battery: step 1, image 2 of 2
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Nokia E61i Front Cover Replacement: step 2, image 1 of 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Front Cover Replacement: step 3, image 1 of 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Front Cover Replacement, Front Cover: step 4, image 1 of 2 Nokia E61i Front Cover Replacement, Front Cover: step 4, image 2 of 2
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Front Cover Replacement: step 5, image 1 of 1
    • Remove the cover by pulling it up and off.
Christopher Patton
208 Reputation
12 Guides authored
Cal Poly, Team 9-63, Walters Spring 2011 Member of Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 2,887
