Nokia E71x Camera Replacement
  1. Nokia E71x Camera Replacement, Motherboard: step 1, image 1 of 2 Nokia E71x Camera Replacement, Motherboard: step 1, image 2 of 2
    • Remove battery
  2. Nokia E71x Camera Replacement: step 2, image 1 of 1
    • Using Torx number 4 unscrew the four 0.5mm screws.
  3. Nokia E71x Camera Replacement: step 3, image 1 of 1
    • Push in four clips to detach the body.
  4. Nokia E71x Camera Replacement: step 4, image 1 of 3 Nokia E71x Camera Replacement: step 4, image 2 of 3 Nokia E71x Camera Replacement: step 4, image 3 of 3
    • Separate the body into two pieces.
    • Be careful not to damage the screen or body. Some force will be needed to separate the body.
  5. Nokia E71x Camera Replacement: step 5, image 1 of 3 Nokia E71x Camera Replacement: step 5, image 2 of 3 Nokia E71x Camera Replacement: step 5, image 3 of 3
    • Remove the bottom piece that is clipped on.
    • Some force will need to be exerted to remove the clip.
  6. Nokia E71x Camera Replacement: step 6, image 1 of 1
    • Using Torx number 4 unscrew the two 0.7 mm screws at the top of the device.
  7. Nokia E71x Camera Replacement: step 7, image 1 of 2 Nokia E71x Camera Replacement: step 7, image 2 of 2
    • Once screws are removed detach back of phone from the motherboard.
    • This will require some force and maneuvering. Be careful not to break phone back or motherboard.
  8. Nokia E71x Camera Replacement: step 8, image 1 of 1
    • Replace motherboard, ensure that replacement has the same serial number.
  9. Nokia E71x Camera Replacement, Camera: step 9, image 1 of 2 Nokia E71x Camera Replacement, Camera: step 9, image 2 of 2
    • Carefully un-clip camera ribbon. Install new camera.
3 other people completed this guide.
Will Goldby
187 Reputation
4 Guides authored
Cuesta, Team 1-1, Zipperian Fall 2011 Member of Cuesta, Team 1-1, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G1
3 Members
4 Guides authored
1 Guide Comment
Will a Nokia E72 replacement camera part work in the Nokia E71 motherboard? In other words, can one upgrade the Nokia E71’s 3.2 MP camera to 5.0 MP using a spare part made for an E72?
Gam - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 26
All Time: 1,617
