Nokia E90 Battery Cover and Battery Replacement
  1. Nokia E90 Battery Cover and Battery Replacement, Battery Cover and Battery: step 1, image 1 of 1
    • In order to remove the back cover, you must press the indicated button.
  2. Nokia E90 Battery Cover and Battery Replacement: step 2, image 1 of 2 Nokia E90 Battery Cover and Battery Replacement: step 2, image 2 of 2
    • With the button pressed, apply light pressure and slide the back cover off.
    • This will allow you to access the battery
  3. Nokia E90 Battery Cover and Battery Replacement: step 3, image 1 of 1
    • In order to remove the battery, pull it out from the same side that the rubber button is on.
To reassemble the back cover, simply slide it back on.
michael mira
14 Reputation
1 Guide authored
Cal Poly, Team 18-21, Garner Spring 2011 Member of Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 5,393
