Nokia G42 5G Screen Assembly Replacement
Manuel Haeussermann
Manuel Haeussermann and 6 other contributors
Last updated on May 7, 2024
1 - 2 hours
Moderate
Featured Guide
OEM Guide
Introduction
Go to step 1
Use this guide to replace a broken screen on your Nokia G42 5G.
This guide is written for the genuine Nokia G42 5G screen assembly. The assembly consists of the screen and midframe together as one part. Make sure you have the correct part before you begin this repair.
Note: This procedure requires transferring your phone's internals into the new assembly.
For your safety, turn on your phone and allow the battery to discharge below 25% before starting this procedure. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery looks puffy or swollen, take extra precautions.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Show more…
  1. Nokia G42 5G Screen Assembly Replacement, Eject the SIM card tray: step 1, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Eject the SIM card tray: step 1, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Eject the SIM card tray: step 1, image 3 of 3
    • Power down your phone and unplug any cables.
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the upper left edge of the phone.
    • Press firmly to eject the tray.
  2. Nokia G42 5G Screen Assembly Replacement, Remove the SIM card tray: step 2, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the SIM card tray: step 2, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the SIM card tray: step 2, image 3 of 3
    • Remove the SIM card tray.
    • When installing either a SIM card or a microSD card, make sure they're in the correct orientation and sitting completely flush with the edges of the tray before reinserting the tray into the phone.
  3. Nokia G42 5G Screen Assembly Replacement, Insert an opening pick: step 3, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Insert an opening pick: step 3, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Insert an opening pick: step 3, image 3 of 3
    • The back cover is held in place by plastic clips.
    • Insert an opening pick under the small notch in the SIM card tray slot.
  4. Nokia G42 5G Screen Assembly Replacement, Release the plastic clips: step 4, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Release the plastic clips: step 4, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Release the plastic clips: step 4, image 3 of 3
    • Position the opening pick at a steep downward angle between the back cover and the screen assembly.
    • Slide the opening pick down the left edge of the phone to release the plastic clips.
  5. Nokia G42 5G Screen Assembly Replacement: step 5, image 1 of 3 Nokia G42 5G Screen Assembly Replacement: step 5, image 2 of 3 Nokia G42 5G Screen Assembly Replacement: step 5, image 3 of 3
    • Turn the opening pick around the corner and continue to slide it along the bottom edge to release the plastic clips.
  6. Nokia G42 5G Screen Assembly Replacement: step 6, image 1 of 3 Nokia G42 5G Screen Assembly Replacement: step 6, image 2 of 3 Nokia G42 5G Screen Assembly Replacement: step 6, image 3 of 3
    • Slide the opening pick up the right edge to continue releasing the plastic clips.
  7. Nokia G42 5G Screen Assembly Replacement: step 7, image 1 of 3 Nokia G42 5G Screen Assembly Replacement: step 7, image 2 of 3 Nokia G42 5G Screen Assembly Replacement: step 7, image 3 of 3
    • Slide the opening pick along the top edge to release the remaining plastic clips.
    • Don't try to fully remove the back cover just yet, as it's still connected with a cable.
  8. Nokia G42 5G Screen Assembly Replacement, Flip open the back cover: step 8, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Flip open the back cover: step 8, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Flip open the back cover: step 8, image 3 of 3
    • With the phone laying screen-side down, carefully lift the right edge of the back cover, opening it like a book.
    • Take care not to strain or tear the attached fingerprint reader cable during this procedure.
    • Lay the back cover next to the phone.
  9. Nokia G42 5G Screen Assembly Replacement, Unfasten the fingerprint reader bracket: step 9, image 1 of 1
    • Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the fingerprint reader bracket.
  10. Nokia G42 5G Screen Assembly Replacement, Remove the fingerprint reader bracket: step 10, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the fingerprint reader bracket: step 10, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the fingerprint reader bracket: step 10, image 3 of 3
    Tool used on this step:
    • Use a pair of tweezers or your fingers to remove the fingerprint reader bracket.
    • Take care not to puncture the battery with sharp tools—a punctured or creased battery may leak dangerous chemicals or cause a fire.
    • During reassembly, make sure to slide the bracket's edge back into its slot under the motherboard cover.
  11. Nokia G42 5G Screen Assembly Replacement, Disconnect the fingerprint reader: step 11, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Disconnect the fingerprint reader: step 11, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Disconnect the fingerprint reader: step 11, image 3 of 3
    • Use the pointed end of a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • Remove the back cover.
  12. Nokia G42 5G Screen Assembly Replacement, Unfasten the motherboard cover: step 12, image 1 of 1
    • A white sticker might cover one of the top screws. Pierce through it with the tip of your screwdriver or use a pair of tweezers to remove it.
    • Use a Phillips screwdriver to remove the ten 3.8 mm-long screws securing the motherboard cover.
  13. Nokia G42 5G Screen Assembly Replacement, Pry up the motherboard cover: step 13, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Pry up the motherboard cover: step 13, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Pry up the motherboard cover: step 13, image 3 of 3
    • The motherboard cover is further held in place by plastic clips.
    • Insert an opening pick under the right edge of the motherboard cover.
    • Twist the opening pick to release the plastic clips.
    • During reassembly, clip in the motherboard cover on the top left first.
  14. Nokia G42 5G Screen Assembly Replacement, Remove the motherboard cover: step 14, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the motherboard cover: step 14, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the motherboard cover: step 14, image 3 of 3
    • Use a pair of tweezers or your fingers to remove the motherboard cover.
  15. Nokia G42 5G Screen Assembly Replacement, Disconnect the battery cable: step 15, image 1 of 2 Nokia G42 5G Screen Assembly Replacement, Disconnect the battery cable: step 15, image 2 of 2
    • Use the flat end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  16. Nokia G42 5G Screen Assembly Replacement, Unfasten the loudspeaker: step 16, image 1 of 1
  17. Nokia G42 5G Screen Assembly Replacement, Pry up the loudspeaker: step 17, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Pry up the loudspeaker: step 17, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Pry up the loudspeaker: step 17, image 3 of 3
    • Insert an opening pick underneath the top right edge of the loudspeaker.
    • Avoid pushing down at a sharp angle, or you risk damaging the interconnect ribbon cable underneath.
    • Twist the opening pick to release loudspeaker from the plastic clips holding it in place.
  18. Nokia G42 5G Screen Assembly Replacement, Remove the loudspeaker: step 18, image 1 of 2 Nokia G42 5G Screen Assembly Replacement, Remove the loudspeaker: step 18, image 2 of 2
    • Use a pair of tweezers or your fingers to remove the loudspeaker.
  19. Nokia G42 5G Screen Assembly Replacement, Disconnect the interconnect cable: step 19, image 1 of 2 Nokia G42 5G Screen Assembly Replacement, Disconnect the interconnect cable: step 19, image 2 of 2
    • Use the flat end of a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
  20. Nokia G42 5G Screen Assembly Replacement, Disconnect the antenna cables: step 20, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Disconnect the antenna cables: step 20, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Disconnect the antenna cables: step 20, image 3 of 3
    • Use a spudger to disconnect both antenna cables by prying their connectors straight up from the sockets on the motherboard.
  21. Nokia G42 5G Screen Assembly Replacement, Unseat the antenna cables: step 21, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Unseat the antenna cables: step 21, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Unseat the antenna cables: step 21, image 3 of 3
    • Use a pair of tweezers or your fingers to lift the antenna cables out of their recess in the frame.
    • During reassembly, connect the white antenna cable to the motherboard before connecting the black antenna cable. Then reseat the antenna cables into their recess.
  22. Nokia G42 5G Screen Assembly Replacement, Pry up the charging port assembly: step 22, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Pry up the charging port assembly: step 22, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Pry up the charging port assembly: step 22, image 3 of 3
    • The charging port assembly is held in place with mild adhesive.
    • Insert the flat end of a spudger underneath the top right edge of the charging port assembly.
    • Pivot the charging port assembly up until you can grip it with your fingers.
  23. Nokia G42 5G Screen Assembly Replacement, Remove the charging port assembly: step 23, image 1 of 2 Nokia G42 5G Screen Assembly Replacement, Remove the charging port assembly: step 23, image 2 of 2
    • Use a pair of tweezers or your fingers to remove the charging port assembly.
  24. Nokia G42 5G Screen Assembly Replacement, Pry up the vibration motor: step 24, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Pry up the vibration motor: step 24, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Pry up the vibration motor: step 24, image 3 of 3
    Tesa 61395 Tape
    $5.99
    • The vibration motor is held in place with mild adhesive.
    • Insert the flat end of a spudger into the small recess on the upper right side of the vibration motor.
    • Pivot the spudger up to pry up the vibration motor off of the adhesive securing it underneath.
    • If you can't pry up the vibration motor with a spudger, use pointed tweezers instead.
    • During reassembly, you can reuse the old adhesive if it's still sticky. If not, replace it with new custom cut adhesive, such as Tesa Tape.
  25. Nokia G42 5G Screen Assembly Replacement, Remove the vibration motor: step 25, image 1 of 2 Nokia G42 5G Screen Assembly Replacement, Remove the vibration motor: step 25, image 2 of 2
    • Use a pair of tweezers or your fingers to remove the vibration motor.
  26. Nokia G42 5G Screen Assembly Replacement, Disconnect the display cable: step 26, image 1 of 2 Nokia G42 5G Screen Assembly Replacement, Disconnect the display cable: step 26, image 2 of 2
    • Use the flat end of a spudger to disconnect the display cable by prying the connector straight up from its socket.
  27. Nokia G42 5G Screen Assembly Replacement, Disconnect the interconnect cable: step 27, image 1 of 2 Nokia G42 5G Screen Assembly Replacement, Disconnect the interconnect cable: step 27, image 2 of 2
  28. Nokia G42 5G Screen Assembly Replacement, Unfasten the motherboard: step 28, image 1 of 2 Nokia G42 5G Screen Assembly Replacement, Unfasten the motherboard: step 28, image 2 of 2
    • Use a Phillips screwdriver to remove the single 2.8 mm‑long screw securing the motherboard.
  29. Nokia G42 5G Screen Assembly Replacement, Pry up the motherboard: step 29, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Pry up the motherboard: step 29, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Pry up the motherboard: step 29, image 3 of 3
    • Insert the pointed end of a spudger underneath the bottom right corner of the motherboard.
    • Pry the motherboard up until you can grip it with your fingers.
    • During reassembly, clip in the motherboard cover on the top right corner first.
  30. Nokia G42 5G Screen Assembly Replacement, Remove the motherboard: step 30, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the motherboard: step 30, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the motherboard: step 30, image 3 of 3
    • Grip the motherboard on the right edge using a pair of tweezers or your fingers.
    • Remove the motherboard.
    • During reassembly, apply small dabs of thermal paste to the marked areas on the new screen assembly. Follow this guide to prepare the motherboard and apply the paste.
  31. Nokia G42 5G Screen Assembly Replacement, Remove the earpiece speaker: step 31, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the earpiece speaker: step 31, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the earpiece speaker: step 31, image 3 of 3
    • The earpiece speaker is secured to the frame with mild adhesive.
    • Insert the flat end of a spudger underneath the bottom left corner of the earpiece speaker and pry it out of its recess.
    • Remove the earpiece speaker.
    • During reassembly, make sure the gold contact springs on the earpiece speaker are facing up and oriented closer to the bottom edge.
  32. Nokia G42 5G Screen Assembly Replacement, Loosen the battery tabs: step 32, image 1 of 2 Nokia G42 5G Screen Assembly Replacement, Loosen the battery tabs: step 32, image 2 of 2
    • Be extra careful to not puncture, bend, or deform the battery during the next few steps—a damaged battery may leak dangerous chemicals or cause a fire.
    • Use your fingers to peel the two outer adhesive tabs off of the battery.
  33. Nokia G42 5G Screen Assembly Replacement, Lift out the battery: step 33, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Lift out the battery: step 33, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Lift out the battery: step 33, image 3 of 3
    • The battery is secured to the frame with adhesive. Pull tabs are provided to separate the adhesive and remove the battery.
    • Use your fingers to peel the center green pull tab off of the battery.
    • Using one hand to hold the phone steady, use your other hand to slowly and steadily lift the center green pull tab up to separate the adhesive securing the battery underneath.
    • If the green pull tab rips, use the outer clear tabs instead.
    • If you have any difficulties with stubborn battery adhesive, you can contact Nokia's phones support.
  34. Nokia G42 5G Screen Assembly Replacement, Remove the battery: step 34, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the battery: step 34, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the battery: step 34, image 3 of 3
    • Peel the battery off of the adhesive film and remove it.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard. Replace it with a new battery.
  35. Nokia G42 5G Screen Assembly Replacement, Remove the battery adhesive film: step 35, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the battery adhesive film: step 35, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the battery adhesive film: step 35, image 3 of 3
    • Grab the bottom right edge of the leftover adhesive film and pull it towards the top of the phone with steady force to remove it.
    • During reassembly, follow these instructions to apply a new battery adhesive film:
    • Remove the battery adhesive film from its liners and apply it to the battery.
    • Align the bottom edge of the battery (the edge without adhesive) with the bottom edge of the recess.
    • Lower the battery down and press firmly to secure it in place.
  36. Nokia G42 5G Screen Assembly Replacement, Remove the interconnect cable: step 36, image 1 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the interconnect cable: step 36, image 2 of 3 Nokia G42 5G Screen Assembly Replacement, Remove the interconnect cable: step 36, image 3 of 3
    • The interconnect cable is lightly adhered to the frame.
    • Grab the bottom of the interconnect cable and peel it up towards the top of the phone to remove it.
    • During reassembly, realign the interconnect cable with the etched-in markings on the frame. Before reinstalling the motherboard, make sure the interconnect cable’s top connector is at approximately the same height as the display cable next to it.
  37. Nokia G42 5G Screen Assembly Replacement, Only the screen assembly remains: step 37, image 1 of 1
    • Only the screen assembly remains.
    • During reassembly, compare your new replacement assembly to the original part:
    • If your part comes with battery adhesive pre-installed, remove its plastic liners before continuing to the previous step.
    • If your part has no battery adhesive, remove the clear liner on the pre-cut battery adhesive and apply the sticky section to the battery well. Remove the opaque liner before continuing to the previous step.
    • If you're reusing your original battery, carefully inspect it for any signs of physical damage. If it's bent, creased, dented, or scratched, replace it with a new battery. Installing a damaged battery is a safety hazard.
8 other people completed this guide.
Manuel Haeussermann
19,496 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,547 Guides authored
43 Comments
followed all your rules and snapped the inside of my phone thank you
Lee Slater - Reply
Hi Lee, sorry to hear that you experienced issues during your repair. Could you provide me with additional information about which step / action caused this? If you assume the repair is not salvageable, please contact Nokia's phones support to get further support.
Manuel Haeussermann -
Pretty straightforward. Followed instructions to the letter - everything went back together fine.
Matthew Dove - Reply
I followed the Instructions and it worked perfectly. Ready in under 1h.
Martin Scholer - Reply
Unacceptable..., screen assembly parts are out of stock.
Could you make it more friendly to users?
Wang, Shou-Cheng - Reply
Past 24 Hours: 16
Past 7 Days: 69
Past 30 Days: 366
All Time: 10,808
