Nokia Lumia 1020 Screen Replacement
  1. Nokia Lumia 1020 Screen Replacement, Screen: step 1, image 1 of 2 Nokia Lumia 1020 Screen Replacement, Screen: step 1, image 2 of 2
    • Use a SIM door key to remove the SIM card and SIM card tray from the device.
    • Use a T4 screwdriver to loosen the captured torx screw to the right of the SIM card tray (the screw will not come out).
  2. Nokia Lumia 1020 Screen Replacement: step 2, image 1 of 3 Nokia Lumia 1020 Screen Replacement: step 2, image 2 of 3 Nokia Lumia 1020 Screen Replacement: step 2, image 3 of 3
    • Wedge a spudger in between the screen and the back of the device, starting from the top left corner of the phone.
    • Gently pry the screen away from the back of the device using slight upward pressure.
    • Slide the spudger down towards the bottom left corner of the device, continuing to gently pry upwards. The screen will now be slightly separated from the back of the phone.
  3. Nokia Lumia 1020 Screen Replacement: step 3, image 1 of 3 Nokia Lumia 1020 Screen Replacement: step 3, image 2 of 3 Nokia Lumia 1020 Screen Replacement: step 3, image 3 of 3
    • Wedge a spudger underneath the silver rectangle in the upper right corner until it pops off the back of the phone.
  4. Nokia Lumia 1020 Screen Replacement: step 4, image 1 of 3 Nokia Lumia 1020 Screen Replacement: step 4, image 2 of 3 Nokia Lumia 1020 Screen Replacement: step 4, image 3 of 3
    • Wedge a spudger underneath the silver rectangle in the lower left corner until it pops off the back of the phone.
    • Completely remove the screen from the back of the phone.
5 other people completed this guide.
Sydney Hostelley
614 Reputation
5 Guides authored
USF Tampa, Team S1-G4, Leahy Spring 2018 Member of USF Tampa, Team S1-G4, Leahy Spring 2018
USFT-LEAHY-S18S1G4
4 Members
10 Guides authored
3 Comments
Topo très utile. Merci.
Il serait bien de préciser que, après avoir déposé l'écran, il faut encore transférer la caméra de l'ancien au nouvel écran.
JPKuypers - Reply
Topo bien clair. Merci.
Il serait bien de préciser que, après avoir déposé l'écran, il faut encore transférer la caméra de l'ancien écran vers le nouvel écran.
JPKuypers - Reply
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 15
All Time: 2,197
