Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement
Video Overview
  1. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement, Touch screen / Digitizer, LCD Display: step 1, image 1 of 2 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement, Touch screen / Digitizer, LCD Display: step 1, image 2 of 2
    • Switch off the phone and remove the battery.
  2. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 2, image 1 of 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 2, image 2 of 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 2, image 3 of 3
    • Remove 8x Torx T5 screws.
    • With a plastic tool, start with separating the middle frame from the down side.
  3. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 3, image 1 of 2 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 3, image 2 of 2
    • The Loudspeaker is on the middle frame.
    • Disconnect the LCD Display flex cable.
    • Disconnect the Touch screen flex cable.
  4. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 4, image 1 of 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 4, image 2 of 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 4, image 3 of 3
    • The Logic board is held by 2x locking clips at the bottom side.
    • Release it and gently remove it from the front frame.
  5. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 5, image 1 of 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 5, image 2 of 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 5, image 3 of 3
    • Put tape on the glass to not scatter pieces.
    • Worm the glass to melt the adhesive.
    • Use plastic tools to separate the touchscreen from the frame.
  6. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 6, image 1 of 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 6, image 2 of 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 6, image 3 of 3
    • After separating, clean up the sticker that remains on the borders.
    • New line.Install the new touchscreen and reassemble the device.
  7. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: step 7, image 1 of 1
    • That's all.
    • Did you do it successfully?
4 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 1,903
