Nokia Lumia 635 630 Display Assembly Replacement with Frame
Video Overview
  1. Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: step 1, image 1 of 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: step 1, image 2 of 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: step 1, image 3 of 3
    • Remove the battery and any SIM and memory cards.
    • Remove the black sticker at the bottom side of the phone.
  2. Nokia Lumia 635 630 Display Assembly Replacement with Frame: step 2, image 1 of 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: step 2, image 2 of 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: step 2, image 3 of 3
    • Use a screwdriver Torx T4 and remove the 7x screws.
    • There are two other smaller screws with the same head size – remove them as well.
  3. Nokia Lumia 635 630 Display Assembly Replacement with Frame: step 3, image 1 of 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: step 3, image 2 of 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: step 3, image 3 of 3
    • Lift the rear bezel and unhook the display assembly flex cable.
    • Don't use a metal tool for disconnecting the flex cable. There are many small elements near the connectors. You could break them. If you don't have a suitable tool just use your nails.
    • Now we have to transfer the earpiece.
  4. Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: step 4, image 1 of 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: step 4, image 2 of 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: step 4, image 3 of 3
    • Put the earpiece on the new display assembly and start with reassembling.
17 other people completed this guide.
ZFix
191,882 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,516 Guides authored
2 Comments
Where do i get the part replacements from to replace the screen and what not?
Nathaniel Ogungbuyi - Reply
Großes Lob an Nokia, das ist noch ein super zu öffnendes Smartphone gewesen! Touchdisplay tauschen war einfach.
Tale Spinner - Reply
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 18
All Time: 10,362
