Nokia Lumia 635 Motherboard Replacement
  1. Nokia Lumia 635 Motherboard Replacement, Battery Removal: step 1, image 1 of 2 Nokia Lumia 635 Motherboard Replacement, Battery Removal: step 1, image 2 of 2
    • Open the back case of the phone using the plastic opening tool.
    • Remove the battery.
  2. Nokia Lumia 635 Motherboard Replacement, Screw Removal: step 2, image 1 of 2 Nokia Lumia 635 Motherboard Replacement, Screw Removal: step 2, image 2 of 2
    • Remove the five screws shown in the photo using the torx Screwdriver 5mm.
    • Turn your phone sideways and you will find two more screws that you will need to remove using the Torx Screwdriver 5mm.
  3. Nokia Lumia 635 Motherboard Replacement, Remove Hidden Screw: step 3, image 1 of 1
    • Remove the black sticker on the bottom left side (As shown in the picture).
    • Remove the screw that was under the black sticker using the Torx Screwdriver 5mm.
  4. Nokia Lumia 635 Motherboard Replacement, Separating Back Cover From Screen: step 4, image 1 of 1
    • Using the plastic opening tool separate the plastic cover from the screen.
    • On the top left corner you will see the screens flex cable attached to the mother board, watch out when separating them.
  5. Nokia Lumia 635 Motherboard Replacement, Motherboard Replacement: step 5, image 1 of 3 Nokia Lumia 635 Motherboard Replacement, Motherboard Replacement: step 5, image 2 of 3 Nokia Lumia 635 Motherboard Replacement, Motherboard Replacement: step 5, image 3 of 3
    • Carefully retrieve the camera and audio jack’s flex that is attached to the mother board as shown in the picture.
    • Retrieve the burnt Mother Board and replace it with the new one.
14 other people completed this guide.
Daniel Robles
828 Reputation
3 Guides authored
USF Tampa, Team 7-1, Leahy Fall 2014 Member of USF Tampa, Team 7-1, Leahy Fall 2014
USFT-LEAHY-F14S7G1
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 8,977
