Nokia Lumia 720 Battery Replacement
Video Overview
  1. Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 1: step 1, image 1 of 3 Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 1: step 1, image 2 of 3 Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 1: step 1, image 3 of 3
    • Remove the SIM card tray and the memory card try.
    • Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
    • Use plastic tools and start the separating the back cover from the top side.
  2. Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 2: step 2, image 1 of 3 Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 2: step 2, image 2 of 3 Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 2: step 2, image 3 of 3
    • Be careful with the volume buttons.
  3. Nokia Lumia 720 Battery Replacement, Loudspeaker & Antenna module: step 3, image 1 of 3 Nokia Lumia 720 Battery Replacement, Loudspeaker & Antenna module: step 3, image 2 of 3 Nokia Lumia 720 Battery Replacement, Loudspeaker & Antenna module: step 3, image 3 of 3
    • Remove the 3x Torx T4 screws.
    • Buzzer / Loudspeacker
  4. Nokia Lumia 720 Battery Replacement, BATTERY: step 4, image 1 of 3 Nokia Lumia 720 Battery Replacement, BATTERY: step 4, image 2 of 3 Nokia Lumia 720 Battery Replacement, BATTERY: step 4, image 3 of 3
    • Disconnect the battery flex cable.
    • Unstick the metal foil from the logic board.
    • Use a plastic tool with a thin tip and unstuck the battery from the middle frame.
    • Battery - BP-4GWA, 2000mAh, 3.7V, 7.4Vh
ZFix
191,882 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,516 Guides authored
3 Comments
I have nokia lumia 720....it can't starting up only shows charging sing..... plz...help me
Amir Hosain - Reply
i have also the same problem is ur problem fixed now ..then pls tell me the solution
pattnayakabhash34 -
Hey guys I really need to know if you can recommend a trusted retailer of spare BP-4GWA here in South East Asia. I am currently residing in the Philippines and it's just hard to buy from Ebay and Alibaba without anyone's opinion. TIA!
nicoangelob - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 5,675
